Great Planes Dazzler ARF
IL
A friend has one, and while it flies ok, it is HEAVY.
I found it to be VERY heavy, so much that the OS46FX on it was not nearly enough. It has ok vertical as long as you have speed up, but it WILL NOT hover.
kit is stronger than arf, builds fast , flies great hovers on a 10x6 picco45 with ease ,marvelous fun fly has been around a long time, lots of variations at our club most with tt46, 0s46 and sc/asp ching engines all flies great also easy to fix as we fly them a little crazy, have fun
I fully agree there is a weak point just in front of the wing. I know this because after building from the ARF and making 6 flights, the fuselage broke clean off just in front of the wing. My OS 46.fx, the fueltank, and the landing gear took off in one direction, and the fuselage with the wings and everything floated to the ground like a leaf. Other than my plane being split in two, the only other damage is a broken rudder from the impact, and a few holes in the covering... But I have no idea how I'm going to fix it short of bolting the two halves back together......What a ripoff...
