how much power for servos ?
AL
I don't like to use standard servos in a acrobatic plane but thats just my opinion. I would use something with a least 50 to 60 in oz of torgue. But on the lighter side I have friends at the field that fly standard servos that never have a problem with them. If your still unsure you can always read the manual and install what the manufacturer suggests.
Banned
You should use something better than the "standard" (appx 45 in-oz, nylon bearing plastic gear) servos.
The ailerons, using one servo each... you should be OK with about 60 in-oz per servo.
elevator, if single servo, you need 75 in-oz minimum...
The rudder will need either a gang of two 54 in-oz or one 90 in-oz.
The throttle... you could probably use a 27 in-oz mini-servo if you wqant. Not much force on that on.
Your plane will put more force on its control surfaces than the Dr1 I'm flying using an O.S. .91 FS. I had to switch to ball bearing servos all around, and the lowest power servo on a flying surface is a 60 in-oz. The Dr1's got ballanced surfaces all around and the rudder has stripped out one 75 in-oz servo, when I had the throttle mechanically limited to 75%... The Cap is faster... more maneuverable, and has bigger control surfaces. Get better servos.
