gp pitts gasser, fully concealed
Other than the zdz40 or zdz50, does anyone have a recommendation for a gasser that will be fully concealed on a gp pitts. I want good power but not necessarily unlimited vertical.
Stinker
Stinker
My Feedback: (48)
NY
I fly mine with a brison 2.4 and a 20x10 prop this ios a nice combo it has a good up line and will hang on the prop. This is not a 3d plane. The setup is better than scale proformance. The brison produces approx. 21 lbs. of thrust and the pitts wieghs 15.5lbs. Just remember on landing that it is a biplane and they do have more drag and will slow down veary quick and the only hole you need to cut is for the muffler. I did however open the front a little for better cooling
Hope this helps
Fred
Hope this helps
Fred
KY
POWER FOR PITTS
BME 50 has way more than enough power
will hover at half throttle ..............
easy to mount using HANGAR 9 big aluminun t mnts.
