 H9 ShowTime & OS 1.08 >
Old 11-30-2005 | 08:38 AM
My Feedback: (13)
Default H9 ShowTime & OS 1.08
You guys that have (or have seen) this combination...
1. Is there enough room in the cowl for a standard Bisson Pitts muffler? I don't mind doing some whittling to make it fit, but if there simply isn't the space...
2. Does the cowl enclose the head? Thinking of cooling/glow plug access here.
3. What sort of engine mount is supplied? For several reasons, I am usually unimpressed with H9's engine mounts or tanks.
4. Big question... balance. Rudder servo up front w/pull-pull, or in the tail?
I'd appreciate any insight. I"ve just about convinced myself to get one of these, but would like a bit of advance info on fitting my gear. I ALMOST picked up an F90 at the LHS yesterday. Glad now I didn't; the ShowTime looks to be more in line with what I want.
Old 12-01-2005 | 09:09 AM
My Feedback: (13)
Default RE: H9 ShowTime & OS 1.08
Hmmm... okay, then.
Can anyone tell me what size spinner I need to acquire for this model?
Old 12-01-2005 | 11:46 AM
SunShyne's Avatar
My Feedback: (68)
Steve
I cant comment on the 10.8 but it should not be too much more than some of thae larger 4 strokers being used by many members. I have a YS 110 on mine and from the looks there will not be enough room for a pitts style muffler space is limited in the cowl for anything large. I could be wrong so im hoping someone using a 2 stroke chimes in. I have the following setup:
- Rudder servo in fuse on a pull pull
- I used the stock mont and drilled it out for the 110. I also used the stock tank, fits perfectly in the formers used to hold it in place during flight.
hope it helps you and good luck
matt
Old 12-01-2005 | 12:13 PM
jlkonn's Avatar
Matt,
When you used the stock tank did you have to "strap" it for the pressure the 1.10 generates?
Thanks!
JLK
Old 12-01-2005 | 12:37 PM
SunShyne's Avatar
My Feedback: (68)
ORIGINAL: jlkonn
Matt,
Thanks!
JLK
I strapped it loosely so it had room to breathe once pressure built up.
matt
Old 12-01-2005 | 12:40 PM
jlkonn's Avatar
One more question if I may?
What did you strap it with?
Thanks!
JLK
Old 12-01-2005 | 01:27 PM
My Feedback: (13)
Thanks, Matt.
I hooked up with PropTop via PM; he has the same set-up I'll be using. You're right about the cowl; one must make a "relief cut" (hole) to accomodate the right front corner of the Pitts muffler.
So, what size spinner? Applying the old calibrated Mark I Eyeball, it looks like 2.75" or 2.5".
Old 12-01-2005 | 08:42 PM
proptop's Avatar
My Feedback: (8)
Just stumbled across your thread here Steve...
Spinner size is 2.5"
