 Protech Funtastic 3D CG problem! >
Old 01-14-2006 | 12:00 PM
Default Protech Funtastic 3D CG problem!
Hi! I am building a Protech Funtastic 3D with an ASP .46 and im having big problems with the CG.. It should med 116mm from the wing leading edge but my models i VERY nose heavy!
What should I do? I cant remove any weight... :-(
Old 01-14-2006 | 02:19 PM
Default RE: Protech Funtastic 3D CG problem!
Shift the battery back as far as you can. I don't know the plane but you may have to completly change the battery position. There are ways and you want to find them rather then add weight anywhere. I've made compartments behind the wing to mount the battery rather then add weight. ENJOY !!! RED
Old 01-17-2006 | 06:26 PM
I am having the same problem with my Funtastic 3D by Protech. At 116mm back from leading edge of wing, it is incredibly nose heavy and i have already shifted the battery pack for the Rx as far back as possible. My fuel tank is empty etc., but it would require a chunk of steel @ 3/4" x 1.5" x 3" placed under the canopy to the back and it was still heavy in the front. there is nothing that a person can move as far as components go and with this plane there is really not any place to add any weight on to the rear of the plane the way it is made.
