Edge 540 wing tube
Edge 540 wing tube
I assume for those who have built it, that you epoxied the center tube in the fuselage? The manaul is silent but I am asking if anyone maybe drilled through the fiberglass tube holder in the fuselage or just glued the tube in place? Am a couple of hours away from finishing and flying mine. Fired up!
My Feedback: (551)
wingtube
No, Spliff, you don't fasten the wing to into the fuselage at all. In particular, don't ever drill any holes in the center part of the wing tube. A hole there would cause the tube to crack and fail in a very short time.
Most people just leave the tube mounted in one wing, but if storage or transportation is a problem that way, you can remove it from both wings and just carry it as a separate piece. (Don't forget to bring it to the field though.) ('')
Jim
Jim
IN
Edge 540 wing tube
I wrapped the center section of the wingtube with teflon tape (pipe wrap) so it makes a nice tight fit with the phenolic tube in the fuselage. I can remove it when I want, but the tube doesn't slide sideways when flying.
