hobbico sukhoi su31
TX
i just repaired my hobicco sukhoi su31 after a crash and now my elevator is crooked what can i do or use to carefully detach the elevator since its cured with medium ca? what tool can i try to make or get that would allow me to do this job safely and carefully?? anyimputs thanks
My Feedback: (91)
If you have a small piece if wire, like a guitar string, it's possible to run it through the fuse and saw back and forth on both sides and get it loose. This has worked for me several times when I needed to remove something that was adhered with
"CA". Good Luck
"CA". Good Luck
