 Dave Patrick Edge or Extra on a Laser 150 >
Old 01-24-2006 | 05:01 PM
tom.laird's Avatar
Default Dave Patrick Edge or Extra on a Laser 150
Hi all,
The DP Edge or Extra is on my list of models being considered for this year. However I'd really like to use my Laser 150 four-stroke but need to know if it is up to the job. I'm not capable yet of wild 3D stuff but will want to at least prop-hang and pull out vertically. Any & all advice gratefully received.
BR
Tom Laird
Scotland UK
www.tomlaird.com
Old 01-24-2006 | 05:37 PM
My Feedback: (31)
Default RE: Dave Patrick Edge or Extra on a Laser 150
i have the dp planes only the extra at this time also have owned his ultimate. The extra is both 3d and imac. i cant speak on your other choice.
Old 01-25-2006 | 09:29 AM
My Feedback: (13)
Tom, IIRC both those airplanes you mentioned are far too large and heavy for the sort of performance you desire with a Laser 150. I've had my Laser 150 for about three years now...
1. Goldberg Ultimate bipe- this is a 60-sized biplane, with 54" wing span, nine pounds. IMO, the Laser 150 is the pefect engine for this airplane; but it will NOT "hover". With a Graupner 16x8, it has enough vertical to fly through big loops and hold an upline for a couple of hundred feet. But the sort of prop-hanging "unlimited vertical" that is so popular these days, just isn't there.
Remember, this is a low-compression/low-rpm engine, designed for extreme reliability with FAI (no nitro) fuel. I run mine on Cool Power 15% synthetic, and get around 8500 max with the Graupner 16x8. The nitro makes for a ridiculously smooth, low tick-over (idle). It doesn't do much for the top end, according to Neil Tidey.
2. Goldberg Sukhoi- This is a larger model, probably close to what you're looking at; 73" span, 11.5 pounds. The Laser 150 was BARELY enough to fly basic manuevers; forget about any "extreme" stuff.
I really have enjoyed my Laser; with the exception of the flexible exhaust extension that didn't hold up (none that I have seen, do for any length of time), the engine has been totally trouble-free and dependable. It has the equivalent power of a Japanese 1.20, IMO. Which means that nine pounds or so is the upper limit if you want very lively performance. It will fly a heavier plane with no problem; but you'll have to fly it like a REAL plane... i.e., on the wing instead of on the prop.
