Hobbico Spectrum 40 ARF >
Old 01-22-2002 | 06:39 AM
Default Hobbico Spectrum 40 ARF
How dose it compare to other patern arfs?Is it a good flying plane?How is the quality?
Thanks for any info.
Old 01-22-2002 | 11:27 AM
it flys really nice but the quality is not top grade.It has a plastic turtledeck on top and has stick on covering which when cleaned with any kind of cleaner the color comes off partially but other than that it really mimic's a larger pattern plane.Tim.
Old 02-13-2002 | 09:54 PM
I own a Hobbico Spectrum and put in 32 flights before putting it aside for the winter. The covering material is cheesy, but the plane is a very good design for pattern purposes. It flies great with a GMS on the nose, a perfect match which gives great vertical.
The spectrum, However, has one very serious flaw, and i wonder how many other guys have had the same problem. I did not put in retracts. The fixed landing gear has broken on one side or the other an incredible eight times!! And I am a pretty good pilot, having at one time flown Expert Pattern.
I cpmtacted Hobbico on this and they sent me a new wing. The problem is that it is identical to the o ne already on the plane, which has a very flimsy landing gear block design. i've tried a number of solutions , but no final fix.
Anybody out there have the problem and come up with a permanent fix?
