 cm pro giles202 from ak-models >
Old 03-26-2006 | 09:30 PM
My Feedback: (50)
Default cm pro giles202 from ak-models
just received my cmpro giles202 that ak-models sells but nowhere in the instructions(WHAT LITTLE THEY SEND) can i find the recommended control throws any help let me know.
Old 03-27-2006 | 04:41 PM
My Feedback: (197)
Default RE: cm pro giles202 from ak-models
The control throws should be set up to your comfort level and past experiences. Which Giles did you buy? There are three different cm pro models. There is a thread in this forum regarding the 140 size.
Old 03-27-2006 | 09:31 PM
My Feedback: (50)
i have the 140 read the other thrends but still no control throws
Old 03-28-2006 | 10:00 AM
jstanton's Avatar
My Feedback: (14)
Sdwingo
I too would like to know the recommended control throws. I have the Giles 140 also that AK-Models sells and you are 100% correct when you say the instructions don't tell you much.
I have a Sig 4 star 60 that is almost the same size as this giles and I am planning to start with the recommended throws for it if I cannot find them anywhere else. Here are the recommended throws for the 4 star 60.
Elevator: Low = 3/4" High= 1"
Rudder: Low = 1" High = 1 1/4"
Ailerons: Low = 5/8" High = 7/8"
The 4 star has a 71" wing with 920 sq in wing area and it is a very gentle plane to fly so I think these settings my will be a good place to start.
