Reload this Page >
Super Skybolt ARF
Super Skybolt ARF
Old 06-03-2008, 05:03 PM
  #501
Harv2828
Default RE: Super Skybolt ARF
Has anyone tried a 3 blade prop in the Super Skybolt?
Old 06-03-2008, 05:20 PM
  #502
da Rock
ORIGINAL: Harv2828
Works excellently well
Old 06-03-2008, 08:14 PM
  #503
Harv2828
What size for the 3 blade prop for the Super Skybolt? And where do you get the spinner? Thanks for the info.
Old 06-03-2008, 08:16 PM
  #504
Harv2828
What size for the 3 blade prop? And where do you get the spinner? Thanks for the info.
Old 06-10-2008, 09:43 PM
  #505
zaboaa
Maidened my Skybolt with the 125 today (3 bladed prop 14X7) . Flew perfect, used 5" as the CG, didn't require any trim, all electronics in instruction manual posit. The 125 really pulls this baby around. I can't wait to go to high gains tomorrow. It was snap rolling like a ban-chi today in low, can't imagine what it will do in high. Might try a bigger 2 bladed prop also, just to see what the difference is.
Old 06-11-2008, 06:27 AM
  #506
da Rock
ORIGINAL: Harv2828
My Skybolt flies awesome with an OS61. There really are only a couple of 3 blades available for any engine size. That's a 12x6(3) Master Airscrew in the picture. It's one of the props the 61 does it's best with, 2-blade or 3-blade. It does ok on the Skybolt with a 12x8(3) but a 13x6 2-blade is slightly better than the 12x8(3). The MA 12x6(3) is just a touch better than those other two.
Graupner makes some good 3 blades, but I've only found the 12.5x7(3) and haven't had a chance to test it yet. My tests are more than just "see if it seems faster or slower".
The spinner came from Tower. They've got a number of spinners for 3blades. More choice in 3 blade spinners than choice in props !!!
Old 06-11-2008, 07:54 AM
  #507
Harv2828
For the Super Skybolt, where do you measure the 5" CG? Is it from the front of the top wing in the center?
Old 06-11-2008, 08:20 AM
  #508
zaboaa
ORIGINAL: Harv2828
I used the leading edge top wing, just to either side of the Fuselage...
Old 06-11-2008, 11:27 AM
  #509
Vinnie6
Vinnie6's Avatar
The top wing has two 4-40 bolts in the center - a front one and a back one. Mine is balanced right in front of the back one, which is also about 5" from the LE of the top wing. Not to insult the intelligence of all the SS owners who already know about the two bolts, just trying to be very clear.
Old 07-01-2008, 08:56 PM
  #510
gmccluskey
Anyone got a photo of the Saito 100 installed (sideways)? I can't make my mind up between an OS 91 FS II or the Saito 100.
Anyone know if OS is coming out with a new 100 size 4-stroke, similar to the OS FS 81a. That engine seems to turn better numbers than the 91FS II.
Old 07-01-2008, 09:16 PM
  #511
CustomPC
CustomPC's Avatar
yep,
There is an FSa 1.10 coming
http://f3a.sakura.ne.jp/radiocontrol...bbyShow01.html
Old 07-05-2008, 12:27 AM
  #512
Avaiojet
Anyone make a fiberglass cowling for the GP Skybolt?
Wheel pants too?
Somebody must?
Charles
Old 07-05-2008, 08:02 AM
  #513
skorman
ORIGINAL: Avaiojet
Wheel pants too?
Somebody must?
Charles
You can buy a Great Planes Super Skybolt fiberglass cowl and wheel pants through Tower Hobbies.
Old 07-05-2008, 09:33 PM
  #514
f_shawn68
f_shawn68's Avatar
Just bought one of these ARF's and I like the manual, but the covering job is the worst I have ever seen. Spent 7 hrs last night ironing out wrinkles and im still not done. I certainly hope the plane is as fun as you guys have convinced me that it is by your posts. Otherwise, I made a big mistake. A sharpei puppy couldnt compare to the wrinkles in this thing.
What engine would you recommend at a 4500 ft altitude?? I want something with good power as I plan on puting a smoke system in this bird. Im thinking a YS 110, but need to know from you more experienced guys if I can run a YS on 15% nitro???? Ive seen that most run it on 20 to 30%. I can get 15% cheap through the club I belong to, but 30% is difficult to come by.
Thanks for any input you can offer
Old 07-05-2008, 10:08 PM
  #515
summerwind
shawn
the skybolt will be everything you expect in the air, and the bonus is this bird lands like a trainer.
as for the wrinkles, i bought 3 of these kits, but the second one i had to ship back because the covering job looked like it was used in the trainees class.........the rest have all been good.
i gave one kit away and still have my backup kit, but to be honest, the only way i can see needing a backup is if i have a radio failure.............this is one docile bird, but wil do a lot of the pattern manuevers with ease.
Old 07-06-2008, 11:30 AM
  #516
Harv2828
Hey Guys
I'm thinking about a smoke system for my Skybolt. Two questions: would an OS904 stroke be OK and what is the best system to use? Thanks for any help you can provide.
Old 07-06-2008, 04:41 PM
  #517
vahpr
ORIGINAL: gmccluskey
Mines got a Saito 100, sticks out the right side (need to replace the cowl and fix the spinner bolt, but you get the idea).
Anyone tried this with floats? We have a float fly next weekend, I've picked up the 40-60 size GP floats, just wondering if anyone's already done it and might share any wisdom....
Jerry
ID:	985010   Click image for larger version
ID:	985011   Click image for larger version
Old 07-06-2008, 04:50 PM
  #518
vahpr
ORIGINAL: f_shawn68
At 400' msl, my Saito 100 has plenty of power, not ballistic but strong on a 15x6. At 4500 I think you're wise to consider a 110 or 120.....suggest you try it w/o the smoke at first, to get a feel for the power at your altitude and to find your preferred cg....
Jerry
Old 07-13-2008, 12:50 PM
  #519
capt17
Hey guys, I have a used Saito .80 that needs a home. The requirments look like this plane would do nicely but it seems everyone wants a ton of power. I'm just getting strated into some aerobatics so speed and excessive power is not what I need . . . yet. This will be my first Bi-plane too. Right now my main plane is a venture 60 (Kinda like a 4 star). Is the skybolt a good third airplane to mess around with? Sounds like the landings are nice, could I control it in the air puttin' around while throwing in some basic aerobatic manuvers? Thanks for the help!
Old 07-13-2008, 01:15 PM
  #520
skorman
You are going to be so surprised how easy this plane is to handle. For mild aerobatics, the Saito 80 will fly it just fine.
Old 07-13-2008, 01:48 PM
  #521
silver.kiwi
ORIGINAL: capt17
Hey guys, I have a used Saito .80 that needs a home. The requirements look like this plane would do nicely but it seems everyone wants a ton of power. I'm just getting started into some aerobatics so speed and excessive power is not what I need . . . yet. This will be my first Bi-plane too. Right now my main plane is a venture 60 (Kinda like a 4 star). Is the skybolt a good third airplane to mess around with? Sounds like the landings are nice, could I control it in the air puttin' around while throwing in some basic aerobatic maneuvers? Thanks for the help!
I have a Skybolt with a Saito FA.80 swinging a Vess 13X7 sport prop and in my opinion it's a great combination. No, the vertical is not unlimited and you won't be installing a smoke system, but it has all the performance I want. I really like the way this plane flies and so will you. It's a real ***** cat with no bad habits or gotchas......in all it's a great first bipe. Do it.
ID:	989865   Click image for larger version
Old 07-13-2008, 02:00 PM
  #522
capt17
Thanks guys! I'll order mine soon!
Old 07-17-2008, 09:09 PM
  #523
gmccluskey
I just picked up one of these kits and have a question about the finish on the cowl. You can clearly see the cloth weave on the entire surface. The paint coverage is far from uniform.
Is this typical of a Great Planes ARF? I've built numerous Hangar 9 ARF's and their glass parts are beautiful.
I was thinking of clear coating the entire cowl then wet sanding the clear to get rid if the texture and either re-coating or polishing. Anyone got a suggestion for the clear paint that would be compatable with the red paint?
George
Old 07-17-2008, 09:25 PM
  #524
silver.kiwi
George
I'd call Great Planes or Tower if that's where you bought it and have them send you a replacement. Take a picture of it so you can Email it to them and I'm sure they will make it right. That's far easier than a refinish which can sometimes be problematic. The weave is slightly visable on mine also, but I don't really find it a distraction. It is pictured just above your post if you would like to compare it to your own.
Old 07-17-2008, 09:33 PM
  #525
gmccluskey
Silver Kiwi,
Thanks for the reply. I have contacted Great Planes and am waiting to hear from them. I was just wondering if the weave texture is standard for this cowl. I have never seen another one.
Cheers,
George
