Who has built a GP Easy Sport 40 ARF
FL
I downloaded the manual for the Easy Sport Mark II ARF from the internet, I plan on purchasing this model in the next few weeks. I read through the manuaI several times and noticed in the parts list there are a few items not referenced in the instruction manual. Namely the item numbers are:
#9 Plywd Wing Hold-Down Plates Never mentioned in manual
#10 Aft root ribs & #11 Forward roots ribs
These items are vaguely mentioned in the wing contruction part, but it is unclear how to install them or where to install them.
#13 Stabilizer Mounting Base Never mentioned in manual
Any thoughts on this??
In addition, on page 7 it says to install the wing bolt plate 1/4" forward of the trailing edge, but when you see the picture of the plate again on page 10, it is clearly flush with the trailing edge. Which is correct??
Your timely responses would be appreciated.
RE: Who has built a GP Easy Sport 40 ARF
Hi Scooter
All I can say about this is go ahed and get the plane and do just exactly as it says in the book that comes with the plane as it practiclly puts itself together. As for the engine, put on a .46 and this plane flies great! I put a .52 on mine and it is awsome. It flies like a trainer but will do more stuff. One thing I would reccomend tho when you get to putting the horiz stab on cut the block out on the back of the fuse and assemble it from the rear. Use your hobby knife to cut it cleanly and save it covering and all then epox. it back in place when you have the horiz. stab in place. If you try to slide it in from the side you won't get a good glue joint (I found this out the hard way and my stab came loose on the bottom side and cracked the fuse forward of the stab)
Have fun with it
clemrick
Have fun with it
clemrick
KS
I just downloaded the manual myself, waiting for my Easy Sport 40 to arrive, and noticed the exact same thing. I had planned to speak with the local hobby store about it when my plane arrived. Any updates on your end?
NY
I believe that once you are holding the parts in front of you, it is obvious where they go, despite the vagueness of the manual. I built this plane and cannot remember having any problems with the manual, and didn't have any extra parts left over. Anyway, it is a great plane and the trike gear is great for preventing nose-overs.
Have fun
Have fun
KS
Well mine arrives Wednesday. I went through the wing attachment one more time in the manual I downloaded and still just don't see any reference to those root ribs. EVERYONE that I've talked to and read on here says that this plane goes together easy enough so I'm just going to start Wed night, go slow and make sure everything fits correctly. Thanks for the info.
My Feedback: (99)
MD
I got one a few years ago when it had the shelf paper covering .I flat wore out a MDS40 on it the plane got soo fuel soaked I finally had to retire it.You will not be unhappy with the plane.Just one mod I made was made mine a taildragger,do not like trike gear too hard on fire walls on not to perfect landing.Besides that she flew like a champ slows down like a trainer for landing.
KS
Well the plane came early, I picked it up today. I found that the manual that actually came with the plane and the one available online from Greatplanes are different. The parts list with the plane is a lot more abbreviated and easier to read and does not contain the wing root ribs mentioned in the online version. It appears that the manual online is for the Mk I version but the plane being shipped now is the Mk II (even though the online manual says the plane is covered with Monokote). Either way, if you get an Easy Sport 40 these days it's covered with Monokote and the instructions are about as easy as it gets. I've spent 2 hours so far working on the plane and have already completed the wing, fuel proofed the fuselage and prepped the fuel system. So far, so good.
FL
Triggerfish talked about fuel proofed the fuselage. I am just starting my first build, and it's a Easy Sport .40. ARF. What do I need to do to fuel proof the fuselage. Is sounds like a good idea. How is your build going. You are probably flying the bird by now, any tips for a newbee builder.
ORIGINAL: Mr B
The epoxy/alcohol mixture will go on nice and light, but dry into a fuel-proof coating.
