Hobbico sukhoi
Hobbico sukhoi
I am thinking about buying one of these to put a 91 os four stroke i have in..i was looking at this and also the seagull extra 300s anyone have any experience with either of these planes..and maybe some comments on both..i would really like a cap for this engine in a 60 size but it seems that most of the planes i see are either 40 size or need a bigger size engine.I am at altitude and have to keep to the bigger size of the range or the plane will be a dog thanks Kieth
My Feedback: (10)
VA
RE: Hobbico sukhoi
I have the Hobbico Sukhoi w/ a OS.91 4stroke. I maidened it a few weeks ago & love this plane. Flys like a much larger plane, very solid & Its a floater on landings. I haven't put it through its paces yet but for $150.00 it a great buy. The cowl is beautiful & the plane is very well constructed. The only thing I'm not crazy about is the covering, its not monocoat. If using the 91 make sure you reinforce the firewall a little. If anything happens to mine I would not hesitate to buy another.
My Feedback: (7)
RE: Hobbico sukhoi
I have flown the Seagull 300 with a magnum 91 2 stroke. It flies well, but the ground clearance is not enough to use a 14" prop, so I was running a 91 with a 61 prop size (13X8). Actually, that is more prop than a 61 would like, but you get the idea. I swapped out the 91 for a Thunder Tiger 61 with a 13X6 prop and got very good flight manners with that combination, with less vibration than the 91 puts out.
Bottom line: I think the ground clearance issue makes this plane not a good choice for a 91 size engine, as you don't get the full benefit of the larger engine.
RE: Hobbico sukhoi
I have the Seagull Extra 300, I love it
I had a SuperTigre G61 in it, but felt it was not enough, so I put a Thunder Tiger 91 4-Stroke and flies real good.
I have a 14x6 prop and have never touched the ground with it (the prop), I just had to add slightly bigger tires.
Joseph
Joseph
