Hangar 9 Pulse XT---hinges?
Has anybody built/setup one of those Hangar 9 Pulse XT 40??. Did you have to attache the hinges to the ailerons and elevator and glue them into place. Of all the kits I have done I always have trouble with the aligning and glueng of of the hinges. I hope they arre already attached??
THANKS !! in advance
Stashu aileron
Stashu aileron
TX
if you use the technique of putting t-pins in the middle of the hinges they will stay put when you slide the aileron onto the wing. it doesn't take a lot of CA to get to stay in place.
KS
Im in the middle of assembly of the pulse only a few issues but easy to remidy.But when i read their it said no gluing bolt together assebly you can imagine my suprize when i found so much to drill and glue
KS
Im in the middle of assembly of the pulse only a few issues but easy to remedy.But when i read their add it said no glueing bolt together assembly you can imagine my supprize when i found so much to drill and glue
ORIGINAL: dshemelrick
Wow, a bolt together plane would be great!! Maybe a bit heavy with all those bolts...
In the ad, they are referring to the method used to hold the wings in place. The exact quote is "The bolt-together assembly, and the 2 piece wing make the pulse a cinch to store". Under that, they show a picture of how the 2 piece wing is bolted to the aircraft.
