 Tower's  Dazzler or 40 Uproar >
Old 07-26-2006 | 07:40 PM
The Toolman's Avatar
Default Tower's Dazzler or 40 Uproar
Was thinking about these 2 planes, but I haven't seen much posted on'em here.
Ronnie
Old 07-26-2006 | 09:45 PM
KojakDave's Avatar
Default RE: Tower's Dazzler or 40 Uproar
I'm looking at the TH Uproar 40, too, but I'm not sure if the engine I have (OS 61 FX) would fit on it...any suggestions?
Dave
Old 07-26-2006 | 09:48 PM
Tcat1000's Avatar
My Feedback: (34)
Hi............Both are good planes, but if you go with the Dazzler (ARF) make sure you beef up the fuse in the area of the landing gear. (front of wing. They are noted for snapping the fuse in half in that area if you land hard! (just don't land hard!
I have the ARF Uproar with a OS 46 AX running a APC 12.25-3.75 prop. I cut 1/2 inch off both ends, rounded the ends & rebalanced it. Three inch foam wheels on the gear, & also beefed up the weak area same as the Dazzler & several other areas. This plane hauls AS*! It comes in as slow as most trainers if not slower. This plane in fun. Again.............just be sure to re-inforce some of the weaker areas.
Have fun.................
Old 07-26-2006 | 09:51 PM
Tcat1000's Avatar
My Feedback: (34)
Ummmmm.........................61 FX on the uproar....................I don't think so
Old 07-27-2006 | 02:48 PM
My Feedback: (9)
I am using a Magnum .52 on the uproar and the Dazzler. Great with skis and hoping great with floats. That motor flys it ballistic. A 61 would fit but may make it a bit nose heavy. Post pics and results
Old 07-27-2006 | 03:59 PM
Ernie Misner's Avatar
I say get the Uproar... I did. The Dazzler is the same plane except it comes out heavier because of the built up, rounded, turtle deck.
Ernie
