Split elevator problem Cap 232
Hey Guys
I got a overseas cap 232 with crap for directions 1/4 scale ... It has a 2 piece
elevator with a metal u link between them. I want to run this on one servo. Is this a safe way to do this? I drilled the holes in the elevator and I can epoxie the hole assembly but I have not seen this set up before. There is a servo mount on the other side if you were to do a pull pull rudder. But, this is set up for rudder on the other side.
I am using hi torque futaba servos
in this application. S3010s
David
David
