TWIST 40 and .61 engine?
My Feedback: (17)
MN
I have Twist with a OS .61FX on it and it is the perfect motor. I only use full throttle while accelerating vertically, otherwise she will hover just above half throttle. You don't have to add any wieght to the tail as long as you place the battery in the right spot. Good luck.
Adam
Adam
I flew a Pizazz, very similar in size/weight with an OS61. I used a 13-5 with good results. It would hover around 2/3rd throttle. I am curious if a 61 2 stroke would turn a 14-4. I Didn't discover the APC 14-4W until I got a Saito .82
