Hangar 9 PNP cub questions
My Feedback: (72)
For those who have the PNP cub how are you re-fueling it the cowl makes it tricky to get to the fuel lines? How many flights did you get on the stock 600mah battery.
Any important build or flying types welcome.
thanks
Peter
thanks
Peter
FL
RE: Hangar 9 PNP cub questions
Hello, I to have installed a Sullivan fueler on the right hand side about half way up on the cowl, You have to make a bracket to hold the fueler and then fasten to the fire wall. Sig makes a L bracket for fuel valves, but I don't remember the part # all you would half to do is get a piece of flat stock about 2'' long and approx 1'' wide and bend a 90 degree bend approx half way on the long side and drill out a hole for the diamater of which ever fueler you use and a couple on the other side of the bend for a few screws to fasten to the fire wall and walla your done, of course you will have to cut a hole in the cowl to refuel threw.hope this helps,if you would like a few photos I can send them.picture is worth a thosand words!
