 Twist 60 Saito Engine Choice >
Old 09-03-2006 | 01:02 AM
My Feedback: (16)
Default Twist 60 Saito Engine Choice
I have just purchased a Twist 60 and I can not decide what Saito to use.
I have a 82 and a 100 that I can use.
Should I use the 82 to save weight or use the 100 for more power?
Also on the chosen engine what prop would be recommended?
I am a sport flyer NOT a 3D flyer.
Any suggestions or advice will be very appreciated.
Regards.
Brian
Old 09-03-2006 | 07:30 AM
Tcat1000's Avatar
My Feedback: (34)
Default RE: Twist 60 Saito Engine Choice
Hi Guy...........Put the Saito 100 in it as the 82 will be a tad bit whimpy for that bird. I just bought one also, and am putting the Saito 125 or the OS 120 AX two stroke in it as I have both.
I am currently flying the H9 Ultra Stick 40 size with the 82 & it is a perfect match, as the 100 will be for the 60 Twist.............
I would also consider gluing the tail feathers in permanatly (I will) after alignment, as this may be a problem down the road if you don't. Good luck
