Reload this Page >
Phoenix Extra 330S 60-90 Size
Old 07-25-2007, 04:02 AM
  #276
photolodge
Default RE: Phoenix Extra 330S 60-90 Size
Ok brothers in flight,
This is my take on the bird.
Only 2 short flights in. One landing to change my pants and the other to check for bean damage.
I put it to low over beans and managed to plow through about 15 rows (sow bean) but managed to land the damn thing.
Boy does this thing drop to nose at slower speed when landing. I got the balance right, any thoughts on this one?
Steve
The guys at the field now call it the "bean dip maneuver"
Old 07-25-2007, 04:09 AM
  #277
photolodge
Sorry wrong photo attached above in previous post!
Thats me with a new Funtana x100 with Evolution 100 engine trouble.
I will try to find the right photo and post it here.
Old 07-25-2007, 09:40 PM
  #278
electron
electron's Avatar
Really that is a surprise... Mine lands like a trainer... What is your planes weight mine, currently mine weighs in a little over 7lbs...?
My guess it's wing loading, CG balance, or elevator rates, this plane should land soft and easy...
Electron
Old 07-25-2007, 10:04 PM
  #279
wc524
I don't think so....move the CG back....
It should not drop due to a thrust line, it's got to be the CG being too far forward. As you saw in my videos it lands like a trainer....3-point landings all day long.[8D]
Old 07-27-2007, 05:15 AM
  #280
photolodge
wc524 ,
I watched your video and you never land it so I cant tell!
You may have a point about the CG to far forward, I will check it out when it stops raining.
Steve
Old 07-27-2007, 05:17 AM
  #281
photolodge
wc524
Could you measure your CG and send me the numbers?
Steve
Old 07-29-2007, 12:04 AM
  #282
wc524
130mm back of the leading edge. It is not tail heavy enough for me still.
[link=http://www.rcuvideos.com/item/P1P7J46SW6FY79MD]Phoenix Extra 330 Video 1[/link]
Old 07-31-2007, 09:11 PM
  #283
electron
electron's Avatar
Well the parts are in and the electric conversion has started here are a couple photo's of the brushless motor mounted.. This outrunner has major vertical written on it..
Electron
ID:	733367   Click image for larger version
Old 08-05-2007, 05:10 PM
  #284
electron
electron's Avatar
Well I took my electric Phoenix Extra 330S out this weekend and it is totaly amazing.. I can hover at half throttle... It takes like 15 feet to take off.. Vertical is so totaly unlimited it's crazy... I need to get me a video camera or digital camera that does video so I can show this electric conversion in action.. The guys at the club were amazed at the unreal power this setup has. I am getting 10+ minute flights almost all 3D flight with no problem at all. I am thinking of converting my whole hanger to electric as there is no mess and no dead sticks..
Here is the completed Phoenix Extra 330S electric..
The setup is......
Great Planes Rimfire 50-65-450 Out-Runner Brushless
Great Planes Brushless Motor Mount Large Motors
Great Planes SS-80 HV Brushless Motor Control
15X8E APC prop
HECell 4000-6S 15C continuous 22volts
Astro 109 Lithium-Poly charger with LCD display (I had a triton but it will only charge 4 cell li-polys)
Output is 1268 watts on my wattage meter and plane weighs in at 8lbs 2oz..
ID:	736310   Click image for larger version
ID:	736311   Click image for larger version
ID:	736312   Click image for larger version
ID:	736313   Click image for larger version
ID:	736314   Click image for larger version
ID:	736315   Click image for larger version
Old 08-08-2007, 02:57 PM
  #285
manyu
any body there having problems with the landing gear?
Mine got all bent due to some bumpy landings and now how should i straighten the full bent gear?
Manyu
Old 08-09-2007, 06:58 AM
  #286
wc524
First take it off the plane then put it in a vise and bend it with pliers or your hands. Good as new!!
Old 08-09-2007, 08:40 AM
  #287
preparation_h
Yeah, my landing gear is sucking. To be more precise my landing is sucking with this plane. I don't know why but it's the hardest bird I've ever had to time the flare correctly. I'm always too early or too late. Mine just doesn't sink like other planes I've had. The only times I've had good landings with this plane are with dead stick approaches.
My landnig gear went from having scurvy to a plane doing the splits! I just take them off and stick them in the vice. go fly, repeat. It's starting to get old.
Old 08-09-2007, 03:35 PM
  #288
manyu
yaa wc524.. a vise and the pliers would work but i even lost the shape... the landing gear jus s.cks... its made of too poor a quality...
manyu
Old 08-25-2007, 11:22 PM
  #289
srothsch
I am putting together my Phoenix 330S with a supertiger 90 engine. I understand that the engine mounts at 270%, but when installed it does not seem right. The center of the engine is to the left of the center of the fuse when looking at the nose. The cowl has to be cocked way to the left to clear the engine to a point where you can see the cowl is misalligned. The cowl does not fit very well at this angle. Has anyone had this problem?
Old 08-26-2007, 09:54 AM
  #290
backfire
I just used the same engine and the cowl fits OK. Is it possible you have the motor mount brackets upside down?
Old 08-26-2007, 11:39 AM
  #291
srothsch
You are correct. I had the mounts upside dowm. It fits perfect now. Thank you for waking me up.
Old 09-03-2007, 06:35 PM
  #292
wareagle79
Electron any video??? Been waiting like a month now... Need me to mail my Camcorder?
Old 09-09-2007, 11:04 AM
  #293
playntraffic
playntraffic's Avatar
I got a new engine for my Extra. It is a SK90 two stroke. It runs like a champ. I am using a 15x6apc prop. The thrust is fantastic. It will go vertical for days. I got a few pictures from a guy at our club.
Knife edge passes are real clean. It has plenty of power for everthing that my skills can handle. The new motor took the place of a TH75. The Tower motor is good too, but spinning a two inch longer prop is nice.
sorry for the double pictures, first time uploading photos []
ID:	759573   Click image for larger version
ID:	759574   Click image for larger version
ID:	759575   Click image for larger version
Old 09-09-2007, 01:40 PM
  #294
manyu
hey thats g8 Pics...
How did you get that canopy black.... its looks quite good !!...
Old 09-10-2007, 06:05 PM
  #295
playntraffic
manyu
thanks. I used spray can tint from the local hobby shop. it is sold with the RC car paints. Works well.
Old 09-18-2007, 02:42 AM
  #296
Crashtruk
Crashtruk's Avatar
I am removing my ST 2300 and installing a ST G 90. The 2300 was just too big, too much power for the airframe and the pilot
Old 09-29-2007, 02:14 PM
  #297
davidsai
Hi there, i have finished putting together the 330, it balanced great at 120mm with tank in rear part of tank location, engine 61 fx os, battery a 5 cell in back tray. I cured fire wall with 30 minute epoxy, tried to put a simpe¿le onm board glow plug driver but it did not work with either sub c rechargable or c battery will see later. notece the baffle on right side of engine compartment this to help on redirecting most of the air flow towards the engine head.
pictures
ID:	772634   Click image for larger version
ID:	772635   Click image for larger version
ID:	772636   Click image for larger version
ID:	772637   Click image for larger version
ID:	772638   Click image for larger version
ID:	772639   Click image for larger version
ID:	772640   Click image for larger version
ID:	772642   Click image for larger version
ID:	772643   Click image for larger version
Old 10-02-2007, 08:16 PM
  #298
davidsai
here are some more pics, here you can see the onboard glow driver simple battery and tongue swich controlled by trhottle servo arm it turnons on when 1/4 carburetor opening.
the wheel covers and landing gear fairings will be install after the tryout flights
on board glow driver one battery 1.2 rechargable the c cell does not worked for me. the orange cable is twisted on the glow plug nipple and heat shrinked and tied with nylon strap. the black cable goe to mass fo engine anywhere and the contorl is a switch . the swicth is glued to servo and tied wit the pink nylon strap.
did evryone reversed the carburetor position _???
ID:	775318   Click image for larger version
ID:	775319   Click image for larger version
ID:	775320   Click image for larger version
ID:	775321   Click image for larger version
Old 10-03-2007, 12:17 AM
  #299
electron
electron's Avatar
No video because no plane... I crashed it back a month or so ago. I lost the pull-pull cable on the rudder during take off it snapped rolled the rest is history, word of advice don't use the cheap hardware that comes with the plane. It was a shame it was a great flying 60 size electric..
Old 10-16-2007, 10:16 PM
  #300
monkeygutz69
electron , sorry to hear this. Did you get a new one?? I was supposed to get Mine today but UPS didn't show!!! I have been following this thread for the last couple of weeks when I saw it and because of this thread I decided to get it. Looks like a great lil plane. I have a Saito 125 waiting. I was curious about the hardware.. So,it is no good??? I thought the Pull-Pull would be great.is it not strong enough???
I was disappointed that so few have held an interest in this plane. I have been hoping to find one plane that was just "ME" and get another one as a spare then fly it like I rented it..It is such a pretty bird.
I'm using all the tips and tricks I found here on Mine..I will post some pics in a week or so, just in case anyone is interested.. Best Regards, MG
