Who makes a good pull-pull assembly?
I've been shopping around for a 60 sized aerobat and finally decided own the Seagull Edge 540. I'd prefer to do a pull pull on the rudder (after seeing how positive response is on my profiles). Whose setup would you recommend?
Thanks!
Thanks!
My Feedback: (18)
MO
One answer... http://www.aerografixs.com/ Excellent product, excellent customer service. The kevlar setup it really really strong too....
Du-Bro's is ok, but used as intended has a high potential to fail, especially the 2-56. Du-Bro uses plastic coated braded wire that you thread through a small drilled hole in a threaded clevis connector. The sharp edges of the connector will cut the cable over time.
I like the Kevlar set-up through an I-bolt. Here is a picture of both. The Kevlar set-up came from Don's Hobby shop in Salina Kansas. He advertises in most of the RC mags.
My Feedback: (39)
IL
Check out Nelson Hobby, heres the site.... http://www.nelsonhobby.com/default2.htm
Give them a call, they will set you up with hardware for your application. VERY good stuff!!
