fuel
Old 11-02-2006 | 06:59 PM
Default fuel
Duraplane aerobat with os 40 has problems with losing fuel/power when pulling vertical or aggresive flying. Any thoughts? solutions?
Old 11-02-2006 | 07:13 PM
My Feedback: (16)
Default RE: fuel
Sounds like the engine is lean.
Does it run faster when you do the pinch test or does it just die?
Old 11-02-2006 | 10:00 PM
Default RE: fuel
which OS engine is it> LA or FX? Check for blow by on the head. May need a new gasket.
Old 11-08-2006 | 09:08 PM
Default RE: fuel
changed/adjusted clunk line, changed plug, richened it up. I think mainly was the richening. Problem solved. Thanks.
