Best YAK for 46CC Gasser
OH
I want to get a Yak for my Brillelli 46cc gas engine, but not sure which is the best fit. I know EF has a 77", Somenzini has a 73" and 85" and I think there are a few others.
Which will be the best fit for my engine and be 3D capable?
My Feedback: (10)
IL
Definitely not the 85" or 87" ers put there.
Wild Hare has an 80in Yak....under 14lbs is what you will need to have spirited 3D, IMO.
the 72 -74 in'ers will be too small.
My Feedback: (18)
LA
WildHare 80" or the Goldberg 77"
I have the Goldberg with a Brison 2.4 - great performance, but I do have a Brillelli 46 on the way that I'm thinking about putting in the Yak and using my Brison elsewhere.
OH
How is the quality of the Goldberg model? I had an EF 68" Yak and it was the best plane I ever flew so I know what to expect with EF. And I have heard nothing but good about the QQ models.
Does the Goldberg have any bad habits?
My Feedback: (18)
LA
I think it's a very well built plane - flies nicely. I'm not a 3d-aholic, and I'm just getting my first dozen flights on mine, but it's very well built. It's not the super-lightweight build that a EF or QQ yak is going to be, but those planes are going to be heavier due to their size. I would estimate that with the same electronics the Wildhare would either equal the Goldberg, or maybe weigh a little less.
I'm still in the trimming and tweaking stage on mine - I need to reduce some throws for more of a locked-in pattern/precision feel - with the increased throws I have it's very quick to respond to aileron and elevator throws, and the Rudder is massive, tons of authority. It does a very impressive knife edge spin - so impressive I almost kept it locked in too long and didn't get pulled out in time.
I'll put mine together tonight and weigh it on a digital scale - mind you I haven't taken any weight saving measures on it. No carbon, I'm running a spinner and wheelpants. 2700mah RX NiMH, I even have to use a reversing adapter for my elevator servos (Futaba 7C doesnt have dual elevator trim programming) I am only using one servo per wing panel - it is built for dual servos per wing half (so that a buyer could use dual standard servos instead of a single high-torque.)
My Feedback: (18)
LA
Oh, and the EF Yak is a 74" now, not 77". Brillelli is actually running a package deal that bundles the 46cc and the EF 74" yak and some accessories for $900 I think.
OH
I think it is down to the 74" EF or 73" QQ. I have heard nothing bad about either.
Is either one more durable? I fly off grass so if one can handle that better, that would be my decision maker.
My Feedback: (18)
LA
There are some pretty dedicated threads on RCU about both - generally in the 3D forum. Look for the one on the QQ yak started by Aerobob - he did a build on that one with the Brillelli 40. Per Brillelli the 46 is more powerful, but only about 3-4 ounces more with the new muffler on it. Bob even has some video posted so you can see how the engine pulls the plane. Although he has a dead-stick that turns into a dead-yak.
