Creek Edge 540 CG? >
Creek Edge 540 CG?
Creek Edge 540 CG?
Old 01-31-2003 | 02:05 AM
Default Creek Edge 540 CG?
Im about to finish up a Creek hobbies Edge. Does anyone have the CG? How many inches from the leading edge?
Old 01-31-2003 | 03:33 AM
MHawker's Avatar
My Feedback: (16)
I don't know about the Edge, but with my Creek Hobbie's Extra, the range is 26-30% back from the leading edge. I would think you could apply that same range (which seems fairly typical among other planes I've seen) to the edge. It works out to about 4.29-4.95" on the Extra's 16.5" chord wing.
If it's anything like the Extra I would go a little on the nose heavy side of the range. The Extra was very hard to fly when I was (embarrassed look) past the tail heavy side.
Mike
Old 01-31-2003 | 08:27 AM
Hank68's Avatar
Default CG
I have the Creek Katana and wasn't real sure of the cg,so I called Creek.They told me that all the planes should start at 4 1/4 inches from leading edge for a starting point.Depending on your flying style should dictate where you go from there.Hope this helps.
Hank
Old 01-31-2003 | 04:09 PM
Thanks much guys.
