Twinstar dent!
I have a bit of a dent on the wing of my Multiplex Twinstar. Does anyone know the best way of getting it out or what to fill it with?
I tried a gentle hairdryer but the foam particles started to rise a little bit, so I am a bit wary of what to do?
Hi Sarah. I had a Twinstar a while back.Great airplane.Heat ia definately a no no on foam.If the dent is not too big you might try cutting a piece from the battery compartment and splicing it in.I'm not sure what filler would not hurt the foam.There is an expandable foam that you can buy .It might work.Good luck. Tim
