Servo Recommendations for the Magic ARF >
Old 02-07-2003 | 02:30 AM
Default Servo Recommendations for the Magic ARF
I’m a bit nervous about using cheap standard servos on this ARF, seems to me it’s going to need servos that are fast and with more torque. For the ailerons and rudder Any recommendations? I like to use Futaba or Hitec.
Thanks.
Old 02-07-2003 | 03:55 AM
MHawker's Avatar
My Feedback: (16)
I have standard servos on mine. I believe they are the 3004's (or 3001's)? Whatever came with my 9C. They work just fine.
Mike
Old 02-07-2003 | 04:42 AM
Razor-RCU's Avatar
My Feedback: (50)
Default No problem...
148's, 3001's any standard servos are fine*
Even thought this plane might be overpowered (Which engine u using?) It is still very light and fairly slow because of the thick wing-
james
Old 02-07-2003 | 12:04 PM
Default Re: No problem...
james
I'm using an OS 46 FX.
Old 02-07-2003 | 04:53 PM
MHawker's Avatar
My Feedback: (16)
Same here. Go with standards and you'll have no problem. If you really want to go more, Hitec 605's are not too expensive and might be more what you're looking for.
I have not tried any of the mini servos, but they would save you some weight, which is never a bad thing.
Mike
Old 02-07-2003 | 07:43 PM
Default Magic Servos
I used Hitec HS 225 BB servos all around in my Magic. They are light, stronger than most standard servos, faster than most standard servos, give you a little more room in the already crowded fuselage. The gears are a little on the delicate side but will take any flight load I have been able to throw at them, they just don't tolerate crash loads too well. I can't think of any other servo I would use if I put together another Magic.
Old 02-07-2003 | 09:21 PM
I also used the 225's... on 6 volt.
Old 02-07-2003 | 09:22 PM
They have a MG version, that would work better. Agree?
Old 02-07-2003 | 10:55 PM
Intutively MG has got to be better. I've had no problems with the nylons in the past. <knocks on wood> I've got them on a PBF and they've held up suprisingly well.<more knocking>
Old 02-08-2003 | 02:06 AM
what about hitec 525!!
they will give you speed, specially @ 6 V.
Old 02-08-2003 | 05:42 AM
My Feedback: (19)
Do the 225's seem to center well?
