need help
Improper balance
Warped wing
Elevators not in synch with each other
Not laterally balanced
Not enough elevator throw -- yes, I said not enough
Incidence off
Could be anything. It would help if you told us what plane your flying and what setup your using.
Warped wing
Incidence off
It's a tip stall created by too much angle of attack.
It is accelelated by too much after C.G. even it has a correct elevator throw.
It would be corrected by reducing elevator throw, hasitating quick elevator
input, creating washout on the wing tip, moving the C.G. forward, etc.
Tsutomu Mabuchi
Tsutomu Mabuchi
