Pizzaz upgrade to a 90
My Feedback: (9)
This should be fun. My old Pizzaz has been hanging in the shop with out a motor for 2 years. It needs a little TLC. So I thought I would transform it a little and install and old ST 90 I have laying around. I will post a pic or two as it goes along. Yesterday I took a band saw and cut out all the wood engine mounting ply. I need to make room for a Hays mount on the firewall. I got this done with a little brute force and ignorance. My biggest problem I think will be the CG. The Pizzaz has all 5 servos mounted on the CG. So I bought 2 micros for the ELEV I am going to put in the tail. I may also try to put the rudder servo on the bottom of the fuse toward the rear.
Anyway check back and I will eventually have a flight report. A 90 on a 40 size should be interesting.
David
David
