 Modeltech Cub - CA hinge question >
Old 04-28-2007 | 05:47 PM
Default Modeltech Cub - CA hinge question
Hey folks,
I am building a .25 size modeltech cub and I notice that the instructions are telling me to epoxy what look like CA hinges. I have always used thin CA glue to do these. The manual says to apply some oil to the hinge and then put 30 minute epoxy onto it.
Is this a different kind of hinge? Will thin CA due the trick as it always has?
Old 04-28-2007 | 05:53 PM
Default RE: Modeltech Cub - CA hinge question
Mate, looks like you have the instructions for the bigger modeltech cub. they use a plastic pinned hinge instead of the cyno type.
Just use the cyno type the same way you do with other models, with thin cyno.
