 China Models Paints >
China Models Paints
China Models Paints
Old 05-02-2007 | 08:02 AM
Default China Models Paints
I have a China Models Mosquito ARF from GSP. It looks pretty good, and the paint is flat and a little sandy. The paint is also easy to ding and it has scratched in a few places during assembly.
I'm trying to find a paint match or an easy method of touching up. About the best I have right now is latex and then maybe Nelson or polyurethane the whole thing.
Anybody any experience or suggestions?
Cheers for now!
George Coupar
Old 05-02-2007 | 07:42 PM
Default RE: China Models Paints
yep try this out ,,,, most reputable paint dealers have a spectromtoy (badly spelt) but it acurately matches paint perfectly and costs nothing except for paint ,, I would lightly sand model re undercoat in a shade lighter than top coat let dry for 24 hrs then 2 top coats most enamals now are water based and fuel proof anyway thats how I would attack this job ,,someone else may have some better info all the best mate
Old 05-03-2007 | 11:50 AM
Thanks grimmy55.
I know the acrylic Latex is only gas proof but the enamels are fuel proof ugh?
Any idea what type of enamel I should be looking for? I'm thinking exterior house paint?
Old 05-03-2007 | 07:22 PM
My Feedback: (16)
Your cheapest and probably easiest solution is to use water based paints and I am talking about the hobby type like Humbroldt, Pactra, etc. (go to Walmart, etc. for inexpensive paint), do make sure you use the water based one as these manufacturers also make these paints in an enamel base. You will have to mix a couple or three different colors to come up with the one like on the model, it doesn't have to be perfect. The real birds had lots of repaired and patched up areas and different colors touch ups were the norm, you don't think they had the perfect paint to touch up bullet holes, scrapes, etc. at the field, do you?, besides, paint ages and becomes discolored, and when repairing damaged areas they wouldn't be trying to achieve a uniform look for sure.
Once you come very close to the right color, it is best to mask and paint that entire patch of paint of the same color, the edges are best finished free style, if the areas have a sharp contrast, then it is best to mask and paint within the masked area. Applying weathering helps it all come together and after it is all said and done, then spray a clear coat of satin clear (make sure it is fuelproof) to protect the finish and have that glorious look. I am enclosing a side of my (now defunct) Stuka that I had to repaint and touch up because I had the same problem you did.
Old 05-05-2007 | 08:19 AM
Good plan. Thanks!
