 ? Cermark Pitts ? >
? Cermark Pitts ?
? Cermark Pitts ?
Old 05-06-2007 | 07:33 AM
1Eye's Avatar
Default ? Cermark Pitts ?
I didn't find these answers in the threads that popped up on my forum search:
1. What color Oracover or Ultracote matches the blue on the Cermark S-2B? I wanna think it's Corsair Blue (Ultracote) but I'm not sure. Does anybody have a better idea?
2. What prop mfg/size are you all using on the Saito 180 for this airframe?
Thanks for any help.
Mike
Old 05-06-2007 | 08:09 AM
My Feedback: (31)
Default RE: ? Cermark Pitts ?
i use to run 18 x 6W APC or 18 x 6 Menz or Zinger Pro if you r running enough nitro to turn those otherwise use 17" props
Old 05-06-2007 | 08:39 AM
WCB
Midnight Blue ultracote
Old 05-06-2007 | 08:55 AM
1Eye's Avatar
Hey thanks to bothayas ...
I succeeded in poking a hole thru the fuse side while mounting my switch/chg jack (doh) - so I'll go grab some of the midnight blue UC. Just about finished running some fuel thru the 180 to get it dialed in; so far, an APC 17x6 with 30% RedMax helo fuel is working OK. I live/fly at 6,800 MSL and hope to fly this bad boy after I finish the radio setup.
Again, thanks.
Mike
Old 05-07-2007 | 05:53 AM
WCB
You'll like the Pitts. It flies great and looks good in the air. I'm running a Saito 150 w/APC 17x6 on mine and it has plenty of power. I replaced the cabane strut hex nuts inside the fuse with lock nuts. The hex nuts can vibrate loose. Been flying mine almost 2 years with no problems. It lands like a baby carriage.
WCB
Old 05-07-2007 | 07:38 AM
1Eye's Avatar
... I replaced the cabane strut hex nuts inside the fuse with lock nuts.
I did too! Been down that road before ... [8D]
M
