Can you re-shrink monokote?
I have an Avistar RTF.
The covering look good but under the wing and in some spots near the trailing edge it seems that the covering could have been pulled tighter.
Can I use a blow dryer and shrink to covering?
I read on another thread that you can't once it's been already heated.
Another person said you can and a third said it made the condition worse.
Any suggestions?
Any suggestions?
NC
get yourself a heatgun and work in small area's with a mit or soft towel.... let the area cool before moving too far ahead, indeed you can reshrink the covering.
My Feedback: (16)
GA
Covering will shrink different amounts at different temperatures. SO long as you do not exceed the maximum shrink temperature for Monokote, it will still shrink.
NC
yes, ultracote is my favorite but the finish of monocote is top shelf. dave pattrick's models used some metalic covering anyone know what it is.... it has a metalic and pearl finish ....
Originally posted by Hammbone
This is one of the reasons why I prefer Ultracote. Sometimes Monocote just will not reshrink.
Jim
Jim
I never worked with Ultrakote but I sure remember some nice finished models I had that were covered with fabric.
When it was tight it was finished and was very strong.
Never had to worry about bubbles popping up again
Originally posted by esport33
you could have recoverd the whole wing in an hour. dude are you serious here?
I gained more by undoing another persons slop job and feel good about it
so I have to up the setting a bit at a time.
