Any fly DPM Extra 300? Need some help, thanks!
Hi all
Just got hold of a DPM MkII Extra 300 from my buddy. He only have like 5 flights a year ago and he forgot all the setting.
If you kindly can tell, what is the hi/low/expo throw for all the surface.
The CG?
Anyone got the instruction manual?
What is the starting elevator incidence?
Any tips?
My setup will be on Venom 45cc.
Currently it has 3xS9151 on Rudder and Elevator which is more than enough. But the aileron is on twin servo setup each ie S9301. Total is 138oz on each aileron.
All servo is not on metal gear though.
DPM site is down ie the domain has expired. Not sure how to get hold of them.
The CG?
Any tips?
My Feedback: (31)
i use a degree meter and started off wtih degress of throw
elevator 8-10
ailerons 15 low 20-25 high and 35 3d the ailerons are very powerful most plane i run 20 on low
rudder 25 and 45 for 3d
cg depends on the kit 1st version was 5.25 to conservative....
elevator 8-10
