GP Reactor EP
My Feedback: (13)
1 Post
Yes, the wings are removeable for transport. This design has the new wing tube technology so each wing half slides on a tube and is held down by two socket head bolts. You can put any servo you want into it, but anything larger than a mini will require some balsa cutting. A couple of slices with an X-acto and then some little ply strips glued to add some thickness for the screws is all you need.
Since there are two elevator servos you will need a "Y" connector or better a computer radio that can handle two separate elevator servos such as the Futaba 9C.
i think ro347 wants to get some info for the electric version of the reactor
yes i have one and wings arent removable
i fly mine with an axi 2808/24 - jeti 30 plus - aplus 2250mah 16c 3s1p and futaba 3114 mini servos - thats the only type of servos you can put ( mini not standard )
great plane,flying weight is about 800g unlimited vertical with this motor and great performer
the only think i didnt like was the wing - it would be much much better if it was removable but in a small plane like this one dont ask so much
