DA 50 in a DP extra 330 >
Old 03-05-2003 | 05:35 AM
ici
Default DA 50 in a DP extra 330
I just finished my DP extra with the da 50 for power and it has worked out to a nice combo so far.It comes in at 14.3 pounds with the da 50 and didn't have to add any weight to the tail.If the the weather is nice this weekend the fun will Begin.
Old 03-05-2003 | 06:03 AM
Did you use the stock muffler? If so, how much did you have to cut out?
Any pics would be highly appreciated...
Jim!
Old 03-05-2003 | 06:35 AM
ici
Yes I used the stock muffler on it and it did take some cutting to fit it.I also had to move the firewall back 1/2 inch back so it would fit right.
Old 03-05-2003 | 06:53 PM
Default firewall
How come you moved the firewall back? Why not cut a hole in the firewall for the carb?
Any pics?
Just curious
Jim!
Old 03-06-2003 | 12:14 AM
ici
It was easyer to move the firewall than to buy new standoffs and cutting a 2 inch hole in the firewall.It only took about hour and half to to move it seeing how when took the brackets off the firewall fell apart anyway.
Old 03-06-2003 | 12:22 AM
Ok, I see what you're saying. I guess that keeps the gas out of the inner compartment too...
I guess moving the engine back a tad helped with the balance too.
If you ever get some pics of how it fit with the cowl, I would love to see them.
Jim!
Old 03-06-2003 | 02:02 AM
My Feedback: (31)
any pics?
Old 03-06-2003 | 04:34 AM
ici
The pics are comeing.
Old 03-06-2003 | 04:43 AM
MHawker's Avatar
My Feedback: (16)
I'd also be very interested in the performance of the DA50. Keep us "posted".
Mike
Old 03-06-2003 | 04:56 AM
Flyfalcons's Avatar
Sounds ballistic! Have fun
Old 03-06-2003 | 04:58 AM
Did you mount it enverted, lets see some pics.
Old 03-11-2003 | 02:25 AM
ici
Default pic
first pic
Old 03-11-2003 | 02:53 AM
ici
Default Pics
pic 2
Old 03-11-2003 | 03:32 AM
ici
Sorry the so small it was the best i could do.If anyone knows how to make them bigger let me know.
Old 03-11-2003 | 04:08 AM
Could you expand on your setup? 14lb is a nice weight with ignition and all I'm hoping for a little lighter setup to run on a moki 1.80
Old 03-13-2003 | 05:33 AM
ici
Well boys this thing is awsome.Talk about flying a smoke trail it's like a slingshot out of a hover and it still flys a like big fun fly.this is by fare the best combo i have ever had.
Old 03-13-2003 | 05:38 AM
Sounds like it is going to be awesome!!! What size prop are you running and what kind of RPMs are you getting??
Old 03-13-2003 | 05:48 AM
ici
A 21-11 1/2n 3 bladed.I have'nt tached it yet.
Old 03-26-2003 | 12:26 AM
My Feedback: (14)
ICI,
You were certainly right about moving the firewall back to fit the DA50 under the DP Extra cowl.
Tried to squeeze it. Even ordered some standoffs from aerografixs.com I can't wait though....
Heading home to shave off 1/2".
Old 03-26-2003 | 03:06 PM
My Feedback: (38)
ICI
Could you please expand on your radio set up? Are you running twin servo's on the airleron. If dual elevator servo's in the rear where did you end up with placement of the batteries? Where did your CG end up at?
Paul
Old 03-27-2003 | 11:49 PM
ici
I have one 5645 on each airleron with H9 prolinks.I also put cross braceing in the airlerons the stiffen them up and add 8 ca hinges each airleron.I have 5645s on each elevator half with H9 prolinks.As for the batt. i was doing good until i put the true turn spinner on then i had to move the batt to the tale.So i have ordered a lighter spinner form airwild.
Old 03-28-2003 | 02:09 AM
My Feedback: (23)
Did you use the standard gear?
Old 03-28-2003 | 10:50 PM
ici
If u are talking about the landing gear then no im useing carbonfiber gear.
Old 04-18-2003 | 11:19 PM
My Feedback: (27)
I have a similar setup on my DP Extra. DA 50, carbon fiber gear. My weight came out to 15.5lbs dry. I have a hard time believing that there could be 1 lb difference between two of the same kit. Is yours a first edition or revised with the canopy mounted on the large turtledeck? I tried to keep the weight down. Single aileron servos, twin hitec 645s in the tail (needed for balance), and NO extras (not even a pilot.)
I've only flow it twice thus far, but wow! what a combo. More than enough power. In fact, my initial impression so far is that the huge torque effect from the engine makes it harder to fly with precision. (22x8 zinger break-in prop.)
Just my input.
Old 04-19-2003 | 12:00 AM
ptebbe
Is yours the v1 or v2?
