Black Horse Cap 232 engine choice help
Heey Fellas
Havent yet posted in an airplane section on RCU but the guys in the heli department are very useful, and im sure you are too
Ive purchased a Black Horse Cap 232 ARTF plane, in the instructions it says reccomended engine would be a 40.-53. two stroke
could i fit a .70 four stroke, for example an OS FS-70 II ???
I have recently bought a Black horse CAP 232 ARTF 81 inch span model. I have fitted a 50cc gas engine, everything has gone well so far. My problem is that there are no instructions to advice on engine side thrust. The engine mounts supplied for an OS 35cc glow motor would suggest about a degree of right side thrust, also the cowl front where it lines up with the spinner would suggest the same. I have set up my engine to fit the cowl and hoping the side thrust is correct.
Anyone out there any suggestions?
Stuart
Stuart
