Seagull edge 540 60 servo's ?????
MI
I just finished putting together my seagull edge 540. I was wondering if I should use metal gear servo's on the plane. The recomendation is a digital 811. Has anyone built one or flies one? What combo's are you using. I have a saito 100 engine mounted to it with a apc 16x4 prop. Any help or advice on this plane would be great. Thanks JOE
My Feedback: (67)
IA
I used Hitec 635 servo's on my Seagull Edge 540, but that was the first version. The problem I had was at first the plane was tail heavy and I had to put in a pull pull set up on the rudder, and that took the tail heavyness away.
NEDYOB
NEDYOB
