Reload this Page >
Top Flite B-25 ARF (Tecnical, tips, suggestions)
Old 08-24-2013, 06:07 AM
  #3151
GJB737800
Default Bomb Bay Finally Finished
Finally got the bomb bay conversion completed. Based on the wing span kit, allot of work, not sure I would do it again. Just got to finish off engine install then she will be back in the air..
ID:	1912281   Click image for larger version
ID:	1912282   Click image for larger version
ID:	1912283   Click image for larger version
ID:	1912284   Click image for larger version
ID:	1912285   Click image for larger version
ID:	1912286   Click image for larger version
ID:	1912287   Click image for larger version
Old 08-25-2013, 08:52 AM
  #3152
mustang11
Uh huh uh huh now you've done it, one more thing i'm going to add to mine ........ I'm slowly taking the parts out a 'chunk' at a time and going over each one, so far as others have commented this is one 'ell of an ARF, plus NO WRINKLES to be seen.
Unreal......... a definite first for me. I'll be going over the pieces with an iron regardless, I consider it therapy. Good mindless therapy.........
Old 09-11-2013, 08:30 PM
  #3153
kochj
I still have one brand new in the box, everything still sealed in plastic bags. I just never got around to putting this one together.
I have built about 5 mustangs and still have two corsairs from Topflite I have to build. My problem is I buy them faster than I can build them.
Is yours for sale?????
Old 09-16-2013, 02:54 PM
  #3154
Thomas B
I skimmed the thread and for not see anything about converting the Robart TF B-25 retracts to electric operation using the Wingspan models electric actuators. I am more than ready to give up the air pump....
I am leaning with using the Wingspan actuators as the price and quality are pretty good and his customer service on other stuff I bought has been top notch. I also like that the Wingspan actuators do not require a separate controller.
have heard of a few issues with the Robart electric conversions in general on other models. Are the Robart conversions actually out and working in the B-25 retracts? Anyone with first hand experience on any electric conversion of the B-25 Robarts?
Old 09-16-2013, 03:00 PM
  #3155
chris923
My Feedback: (53)
I have Robart gear converted by Down and Locked. They work great. You might find the Wingspan actuators will not have enough power to do the job.
Old 09-16-2013, 03:56 PM
  #3156
Thomas B
Interesting....can you direct me to a report to that effect from a user that converted the same or similar Robarts with the Wingspan actuators?
Would prefer to do the conversion myself and not send the gear away to have it done. I know that Down and Locked has a good product and reputation.
Old 09-16-2013, 04:32 PM
  #3157
chris923
My Feedback: (53)
I friend tried to use them on some ESM gear, they won't "pull" hard enough. Robart gear are heavier then ESM. I also tried E-Door actuators and they don't have any torque at all.
Old 09-17-2013, 07:45 AM
  #3158
Thomas B
Thanks for the first hand info. If you don't mind me asking, what did Down and Locked charge for the Robart B-25 retract conversion?
it looks like the Robart conversions have not made it out to consumers yet....anyone have any first hand experience with the Robart B-25 retracts yet?
Old 09-18-2013, 10:47 AM
  #3159
chris923
My Feedback: (53)
It was 3 years ago, I think it was 450.00 with the control box. But don't quote me.
Old 09-20-2013, 08:00 AM
  #3160
Thomas B
Over the last couple of days I spoke with the gentleman at Down and Locked and with Robart. Turns out that D&L now supplies Robart with their product for the Robart conversions.
So, D&L and Robart sell the same conversion package for about $270.
I would still like to hear from someone that has done the Robart conversion recently.
Anyone?
Old 09-20-2013, 09:18 AM
  #3161
booker-RCU
My Feedback: (43)
Anyone?
I bought the Robart conversion for the Top Flite 1/5 Scale P-51 and 1/5th Corsair . For the P-51 it took maybe 30 min. The Corsair was the easiest. Both work great. Just make sure you don't hook the gear directly to the battery. Always use the supplied controller to move the gear.
Galen
Old 09-22-2013, 11:24 AM
  #3162
Thomas B
Galen
Am aware of the fact that you MUST use the controller.
Robart had a sale going with 10% off electric retracts and conversions so I bit the bullet and ordered the conversion set for the B-25 retracts. During the conversion, I am also going to redo the gear doors as others have done to have the proper cycling sequence using servos, one for each door, using the servo sequencer built into my DX18 TX.
Old 10-20-2013, 02:12 AM
  #3163
GJB737800
Default Finally finished and Flown...
Finished the B25 engine refit and bomb bay conversion. Fly's great although the extra weight is noticeable on the speed of the model, landings especially!! good job I fitted brakes. I do think heavy models fly nicely, very stable, just need the power.
Originally this B25 was fitted with OS81 pump engines. They had a nice amount of power but the vibration was to much in my opinion. After balancing the props to near perfection and stiffening the structure I decided to fit the Saito 120 R3 radial engines to have done with the problem. Good news is that there is little to no vibration now. If I was to build another top-flite kit I would go for the uncovered versions and glass cloth the model. This Monocote stuff just cant take the heat in Dubai, a few minuets in the sun and the model looks like it has been rapped in a plastic bag. Shame they dont make this kit anymore.
Old 02-25-2014, 07:44 PM
  #3164
sharpnr
Okay, I bought the Top Flite B-25 over 5 years ago. I've just pulled it out and started assembly. My first question(figure I'll have more,,,ha) is "Does both sides of the nacelle fit tight against the wing?" The alignment pegs are 3/4 of an inch out, per instructions, but one side isn't fitting snug against the wing.
Old 02-26-2014, 10:14 AM
  #3165
CCFPILOT
Yes, both sides of the nacelle fit against the wing. -- at least it does on mine. Maybe you have it on the wrong wing, of maybe there was a production change between yours and mine. Anyway, good luck.
CCFlyer
Old 02-26-2014, 02:13 PM
  #3166
sharpnr
Thank you for you response, CCFlyer. That's what I thought, but didn't want to mess up.
Old 02-26-2014, 04:37 PM
  #3167
mustang11
I had the same issue and simply deepened the hole in the wing about an eighth of an inch.
Old 05-02-2014, 02:27 PM
  #3168
MLDELARUELLE
Hi Guys,
I built this plane some years ago using 2 x OS 46 AX with a twinsync. She was flying very well. But for many reasons, I did not fly it since 3 years and one of my engine is blocked.
As I won 2 AXi 4130/20 and I've just notice that aircraft-world was doing good sales on ESC, I bought 2 hyperion 90A 12 S to convert it to electric.
But I don't like to have 2 separate batteries to power the engines.
What are your experience using this configuration ? Any issue ? Like one battery failing during flight
I wonder if someone tried to install the ESCs and one 6S 8000 in the central fuselage using long wires between the engines and the ESC ?
Old 06-23-2014, 11:23 AM
  #3169
Sporto
Hello - My left side interior wood structure in the engine nacelle (which houses the retract/fuel tank/engine mount/servo) broke on a hard landing (again...). I have repaired it a couple times with epoxy, but I am not sure it can be repaired yet another time. Does anyone have experience fixing this structure, have an extra one that they are willing to sell or know where I can get one as Tower says they are backordered, but I fear they are soon going to say that they are in reality discontinued. Thanks.
Old 06-23-2014, 11:28 AM
  #3170
Speedracer2112
Speedracer2112's Avatar
I have a few.
Send a PM
Speed
Old 06-23-2014, 11:52 AM
  #3171
Sporto
Originally Posted by Speedracer2112
I have a few.
Send a PM
Speed
PM Sent. Thanks.
Old 06-25-2014, 07:21 AM
  #3172
Sporto
PM Sent. Thanks.
2 PMs sent. Thank you.
Old 06-25-2014, 07:41 AM
  #3173
Speedracer2112
Please give me a bit of time my friend. I will get home eventually. I can't help you until then. I'm a MD and cannot just go home to look for an airplane part. Stay with PMs please.
Speed
Old 07-15-2014, 12:33 PM
  #3174
thetireman1
Guys, I am in desperate need of a nose windshield for mine. Plane rack fell on it and cracked it in several places. Please let me know if you have one. Call me 919 730-9013
Old 11-10-2014, 11:09 AM
  #3175
rzingsheim
Does anyone have an unused engine cowl, fake radial engine insert (black), and decal sheet for the Top Flite B25? Happy to pay a fair price for any or all pieces. I just picked up a B25 from a club member that started it but didn't finish it. He lost those parts. As far as I can see they are not available from Top Flite or Tower Hobbies. Post here how to contact you or call me at 920-921-5419
Roy
