New H9 P-51
FL
Does anyone have any info on the new Hanger 9 P-51. Their web site lists a 1.50 size P-51 that is not yet available.
All it says is (w/retracts and 399$)
Curt
Curt
Just packed the trailer today and heading out tomorrow. The big stang has flaps, retracts, scale tailwheel location ect ect. Sweet flying warbird. See you at Toledo guys.
John Diniz
John Diniz
It is just under 80". The 2.00Ti and the 1.80 are more than enough power for this plane. It is just at 13 pounds with the 1.80 in it.
I can't believe your going to wedge a 1.80 into the .60 size. Can I ask why? I guess with the bigger stang you will put a Zenoah GT-80 with open stacks running on Alcohol and push 180mph!!!!! <G>
Good Luck,
JD
Good Luck,
JD
P-51B,
Uhhhh,,,,,Yeah. This is the only new warbird that we will be showing at Toledo, Ohio.......<G>
Stay tuned for further developments along these same lines. (he said with a grin)
JD
JD
My Feedback: (17)
Do I also see a new T-34 in Horizon's future as well (per the website, of course). And though not a warbird, perhaps a 40 size Funtana?! I did a search for 'NYA' on their website and found these... can't wait to see 'em.
Yes and Yes. The T-34 and the Funtana will be at Toledo.
The Funtana was designed by Sebastiano Silvestri of Italy, just like the larger 1.20-1.40 size Katana he designed. It is an awsome 3D machine. Everyone here is getting one.
Look for a street price around $170 for the Funtana and the T-34. The engine of choice is a Saito .72 for both.
The Funtana does not like to be over-powered. The .72 gives plenty of power to hover and will clime out of sight using an APC 14x4 wide blade prop.
The T-34 is one of the most easy to fly .40-size planes I have ever flown, and there is also the option to install retracts as well.
JD
JD
Good Luck,
JD [/B][/QUOTE]
Yeh, it's going to be something to see. First flight will be spectacular whether good or bad if you know what I mean. The way I see it is teir are some racers stuffing YS 120's on the front of the .40 size WM P-51. So why not a 180 in a .60. We shall see. Take care
Good Luck,
JD [/B][/QUOTE]
just went to my lhs he had the new horizon book with pictures of the new mustang looks just like the 60 size except instead of invasion stripes it has a single yellow stripe on each wing and yellow wing tips 77" span i told him to call horizon and get it as soon as it is available and it does have mechanical retracts. i see a moki 2.1 in my future.
