GP giant super sportster landing gear block
TX
I have read several post that said the landing gear block failed in side the wing of the giant super sportster and was just wondering which failed on yours? Mine was the starboard outside
RE: GP giant super sportster landing gear block
Sorry mate
but
i don't think GreatPlanes makes 2 versions with the one you mentioned :starboard trim scheme!
I searched Tower but not.
Mine is the "standar" one with the white-red trim.
Kostas
but
Kostas
NY
No problems here yet (knock on wood)
Another "Hidden Wonder" from an ARF!
I find all hardwood LG blocks need work. Their 90 degree/sharp inner hole edge should be re-worked to accommodate the natural arc of the wire gear. Work any other areas so that the gear presses in, all the way home, via a snug fit.
A correct pilot hole for the mounting strap screw is key also. Choose a drill bit which is the same diameter as the shank/un-threaded portion of the screw. Drill to full length of the screw. Clean out the drillings. Use bar soap as lubricant during assembly. Check for tightness every so often.
TX
I added transparent red to the fuse and tranparent yellow to the wings the starbord side is the side with the girl in blue
