 RV4 1/4 scale wing mounting... >
Old 01-07-2008 | 10:04 AM
Fastsky's Avatar
Default RV4 1/4 scale wing mounting...
Hi, I see that the big version of the RV4 is a midwing and was wondering if the !/4 scale RV4 has removable wings or is it permanently attached to the fuselage??
Old 01-07-2008 | 11:40 AM
Default RE: RV4 1/4 scale wing mounting...
If you're asking about the GP RV4 - yes, the wing is removeable. It's in 2 pieces that attach to the side of the fuselage and is secured from the inside with 4 bolts.
Old 01-07-2008 | 11:52 AM
Meesh's Avatar
My Feedback: (135)
I just see 2 bolts in mine.
Old 01-07-2008 | 01:08 PM
Iflyglow's Avatar
My Feedback: (79)
It uses two 1/4-20 nylon screws per wing panel.
Old 01-07-2008 | 01:27 PM
Meesh's Avatar
My Feedback: (135)
No it doesn't have 2 screws per wing panel!
It has only one Nylon screw and 2 anti-rotation pins per wing panel. I just finished mine.
Bob
Old 01-08-2008 | 08:33 AM
Fastsky's Avatar
Um, ok! Thanx for the feedback! Either way, it means I don't hjave to take mine back to the LHS.
Old 01-08-2008 | 10:06 AM
Iflyglow's Avatar
My Feedback: (79)
OOPS, my bad. I replied to the thread at work.[X(] You are correct, two anti rotaion pins, and 1 nylon thum screw per panel. I do not know how someone would not under stand it by just looking at it. From my own experience all last summer, I hope you have small fingers, because it is a pain in the arse to get your hands down under the rudder pushrod to install the screw.
Old 01-08-2008 | 11:31 AM
Meesh's Avatar
My Feedback: (135)
Motorman,
Thumbscrew access is not an issue with mine. I used the rear servo tray location because of the heavy Magnum 160 twin engine I used.
Bob
Old 01-08-2008 | 12:01 PM
My Bad!! I was thinking of the anti-rotation pins.
Old 01-08-2008 | 01:02 PM
Iflyglow's Avatar
My Feedback: (79)
I started out with a Magnum .91 2C, switched to Magnum .91 4C. Am now considering dropping in one of my YS 1.10S'S. Luckily for me, they all take the same mount. I have two cowls. I can switch from 2C to 4C in 1/2 hour.
Old 01-08-2008 | 06:40 PM
Fastsky's Avatar
So is the plane underpowered with the 91 2C??
Old 01-08-2008 | 09:14 PM
Whistling Death's Avatar
No it will actually fly pretty fast with a 91 2 stroke. Guys have been putting them in becuase they didn't like the scale speed of a 4 stroke.
Old 01-09-2008 | 10:13 AM
Iflyglow's Avatar
My Feedback: (79)
The .91 2c flew it very unrealisticly. With a 15-6 it had nearly unlimited vertical from take off. The .91 flys very realisticly though. The take off is actually faster with the fourstroke 10', due to the superior throttle responce of the fourstroke vs/ 15 ' for the two stroke (clean out from idleing). The four stroke can climb at 60 degrees from take off were the two stroke climbes out about 75 degree's. My 1.10 should climb out at 90 degree's though and sound right doing it with a scale prop 16-6. I am just not a two stroke guy.
Old 01-09-2008 | 11:34 AM
Fastsky's Avatar
Thankx for the info. I am planning on using a new TH 75 that I have sitting in a box.
