superstar 40 slect ?s please help >
Old 04-15-2003 | 02:43 AM
Default superstar 40 slect ?s please help
My buddy just got a hobbico superstar 40 selct and was wondering about building the wing. is the mfg's recomendations enough or should He epoxy the wing halves together also.
another ? he asked me that I was unsure of is can you paint the stock covering on the superstar?
thanks
Old 04-15-2003 | 03:11 AM
Sunny_B's Avatar
The only weak point is the small brace towards the trailing edge. However, even that takes a licking and keeps on ticking, so to speak. It's a surprisingly sturdy wing. Mine took several dumb thumb goofs and is still usable after almost 2 years. Lee
Old 04-15-2003 | 04:38 AM
Don't paint the covering, Just get some more monakote and put over it.
Old 04-15-2003 | 04:50 AM
Old 04-15-2003 | 05:10 PM
I would probably epoxy the two wing halfs together.......I saw one guy at the field that was advancing past basic flight with his Superstar 40, and when he landed, there was a gap of about 1 inch between the wings!
Mike
Old 04-15-2003 | 06:22 PM
dbow's Avatar
Default Superstar
There is no other way, you MUST epoxy the wing together. Make sure you fit the V brace into the wing before you add glue. This will make sure its a good fit. I had to do a little sanding on mine to get it to fit perfectly.
Make sure you set the wing on a table and put one wing flat, measure the distance from the table and the other wing. It should follow the manual. If its close and everything else looks good, you are ready to glue it up.
Use 30 min epoxy and butter up the inside of the wing where the brace goes, both sides need a good amount of epoxy.
Then butter up the brace real good as well.
Before pushing the wing halves together butter up the ends of the wing halves. Coat everything in this joint with epoxy.
Squeeze the halves together tightly and used a rag with alcohol on it to remove what oozes out between the two.
Use tape to hold the halves together together until the glue has cured.
I would not paint the covering, but if you are going to try it anyway, scuff it up a bit so the paint has something to adhere to.
THis plane will take the abuse, I have put mine through many controlled crashes and hard landings. I have bashed it a bit also, with a 16oz tank, new landing gear, and a couple other things.
Lotsa lotsa patches on the wings and fuse.
Great plane
Good luck
Dbow
