Pitts s12 Jamara ASP 400 radial ARF 175 cm
RE: Pitts s12 Jamara ASP 400 radial ARF 175 cm
No ,it was not as windy as it sounded on the video ,the conditions was ok () I am working on strengthening the landing gear attaching plates ,and hopefully i will fly it again soon. I have some more videos from the flight that i can upload ,but i am sorry about the quality [)]
How is it going with the assemby of you asp? It will look great!
Yep ,its easy to get sidetracked ,here`s another video of the pitts in flight: http://youtube.com/watch?v=F_BmBGFithQ
Kaastrup how is it going with your pitts?
#31
I dont know of any , wait till it pop up on ebay or here at rcu marketplace maybe. I bought mine from Conrad in Germany ,but they dont sell to USA.
#32
Niels, I have this plane, and I fitted a RCGF 65cc single gas engine, all worked out fine, the only concern that I have is the CG I have no idea where it is, as I have no manual. Could you give me the CG that you flew at.
Thank you in advance
Regards
Andreas
Regards
Andreas
#33
Hi , i flew with the C.G. 13.5 cm back from the L.E. ,at the centre of top wing. good luck! Post a report of how it goes and some pictures!
#35
Hi Nils
I have not had the time to do anything on the model lately, but now its on the workbench again. I have looked the model over, and had some thoughts about these;
1) the tail wheel and bracket seems a little cheap to me, the bracket is made of GFK. Also the wood and gluing where you mount the bracket needs some extra/new epoxy.
2) The landing gear on mine is made of GFK (its painted black) and it is very soft - if I bend it a little it makes a creak noise. Maybe it should be replaced with a BOLLY CFK or aluminium one.
3) the cover needs ironing
4) What do you think of the engine mount box ? Should I put a layer off GFK on it for extra strength ???
#36
Hei
My plane has soft landing gear to ,made of gfk ,but the biggest problem was the weak attachment in the fuse ,i had to strenghten it. I dont use the tail wheel ,only the braket as a skid.
The engine mount box was strong enough for my asp 400.
The asp was in the heavy end for this plane i think , so i have bought a crrcpro gf50i for it ,it is much lighter than the asp ,(i had to shorten the nose to get it balanced with the asp) . The plane will be over a kilo lighter with this engine !
#40
How did it fly ? Was the landing gear strong enough? Mine is still on the building board ,fixing the wings. I have also strenghtened the fuse in the front where the gear is attached.
#41
I had the first succesful flight at saturday with the crrcpro 50cc engine installed. I have strenghtened the front area where the landing gear is attached with plywood plates. So i landed it succesfully ! The Pitts is difficult to land ,but now that i have had one landing ,i hope i have learned something
#43
I flew mine saturday, weight is 7,36kg + 400ml fuel. I still need a spinner in the front, but I already thinks its a bit nose heavy for my taste. I flew it with the 22x10 G-sonic Pro prop on the DL-50 engine, and there is more than enough power, vertical is nearly unlimited. When I fly 1/3 and adds full power the plane rolls a bit, because of to much torque from this setup. Maybee a 40cc gasser would have been more like it.
I will try a 23x8 prop, to see if it helps. I did not do any 3D, but I am pretty sure it can with 45 degres on rudder and elevator.
Landings is fairly easy, BUT - after the landing I did not have any rudder function :-(, so I opened the canopy and saw that the hole servo-box for the rudder was brooken off. Actually I think it happend mid air as I was doing some edge flying. But how do they think that a servo-box intirely made of balsa would hold a 12kg rudder servo in place !?!?!?!?
I have epoxied 2 layers of glass fiber all over the area now. I also reinforced the landing gear area, and it holds nicely.
#44
I have not flown the gf50i a lot but so far it has performed well ,easy to operate and lots of power for the 7.5 kg Pitts
Kaastrup ; How long airfield to you fly it of ? i have a 75m long strip ,and it is kinda difficult to land it there ,i probably need more training
#45
Hi nils
We proberly have 80-85 meters, but not more - here is a link to our airfield
http://maps.google.dk/maps?f=q&hl=da...04678&t=h&z=18
I had 3 flights today, the first landing was pretty nice and used 3/4 airstrip - she is able to come in very slow, engine running in idle at about 1800 rpm. 2nd landing was a bit bumpy, and the plane stoped just before the end of the strip. 3rd was again quit easy.
With less than 75-80 meters it would proberly be hard to get her down...But she is able to fly very slow, with out any funny behavier so far :-)
One thing I dont like - the landing gear is way to soft - its GFK. It has hold up until now, but I would like to get a bit harder landing gear on her...
I will post some pics soon...
#46
Long time since last post!
But i am still flying this Pitts s12 ,with the crrcpro gf50i engine. I have rebuildt the plane after an accident, but it is a good flying plane.
i have also adjusted the timing of the engine by moving the sensor counter clockwise a mm. because the engine knocked back while starting. Now it is fine.
How about your Pitts ,Kaastrup?
