 GP Christian Eagle ???? >
Old 01-29-2008 | 06:00 PM
Default GP Christian Eagle ????
Can some one with the gp eagle please give me engine box measurements (distance out from firewall, to the engine mounting plate of the engine box, at the top- bottom- side of the engine box) so I can set up the new engine box on the plane I'm repairing.
Old 01-29-2008 | 09:48 PM
Default RE: GP Christian Eagle ????
you can call if you cant find the measurements and i will pull my cover and measure fore you 256 825 5901 gene
Old 01-29-2008 | 10:18 PM
My Feedback: (50)
Facing the front here are the measurements on mine with a ZDZ40 in it. Top left is 33mm, bottom left is 31mm, top right is 38mm and bottom right is36mm. The engine mount plate (extended firewall) is 133mm wide by 100mm high. Hope this is of some help and sorry about the metric but that is how most of these arfs are made. My calculations from these measurements are 2.1 degrees of right and 1.1 degree of down thrust.
Old 01-30-2008 | 09:39 AM
thank you that is what I was wanting. I appreciate your time.
