Cheap ARF Ideas. >
Cheap ARF Ideas.
Cheap ARF Ideas.
Old 04-23-2003 | 02:34 PM
Default Cheap ARF Ideas.
Sport_Pilot,
I bought the Avistar for about $99 and put a 12 yo Royal .40 (try finding one of those crusty old things nowadays) in it. The isn't flat bottom so it's a bit acrobatic. With standard hi-tech servos and 4 AA's, that thing climbs straight up which totally amazes me considering the engine was old and cheap. Not to mention I'm running 10% nitro while turning a 10-6 prop. Landings are a crawl and climbing after takeoff requires about 1/4 throttle. I never thought I'd ever buy an ARF but I was totally impressed with the kit. No building or quality problems at all and it went together in about 3 hours. So for the price, the workmanship and ease of flying are hard to beat. Keep it in mind.
Chillybee
Old 04-23-2003 | 02:36 PM
RC Havoc's Avatar
My Feedback: (-1)
I still say you get a stick, nothing flys like a stick
Old 04-23-2003 | 08:28 PM
I forgot to mention in my previous post that I've been flying my beater Avistar for five or six years now. Mine is the old heavy covering (not Monokote). I get a lot of grief from my club members because it looks pretty ratty (covering is all cracked and taped over on the tail from oil attack and old age). But I just remind them that ugly planes don't crash. I just re-engined mine from its original O.S. FP-40, and put on an older Supertigre 45 ABC. It now has pretty much unlimited vertical.
I've never crashed it, (well sort of... keep reading) and it has held together well. The other day, during first flights with the Supertiger, for some reason I kept it upright and did not do my usual inverted low passes. Good thing, because when I did my *final* hot low pass, I rolled 90 degrees to do a bank-and-yank pylon turn, and was surprised to find there was no yank -- I had lost the elevator servo. I rolled it back upright, chopped the throttle, and it landed relatively level in the far-out rough field going pretty much full speed. I saw the plane flip up in the air and disappear, and then flip up in the air again. As I headed out to retrieve it, I expected a debris field the size of the Titanic. What I saw shocked me. There it sat on its belly, fuse was fine, wings were fine, tail was fine, and the main gear was fine. The prop was broken at the hub on both sides, and the nose gear was folded 90 degrees back. Wahoo -- no firewall or prop shaft damage!!! A new nose gear and I'll be back in business. It must have snagged on the nose gear, flipped, snagged, flipped, and then landed. It's just to old and ratty to self-destruct...
Old 04-24-2003 | 02:57 PM
RC Havoc's Avatar
My Feedback: (-1)
You should probably recover that Bad boy. Im sure shell be happy you did
Old 04-24-2003 | 03:01 PM
RC Havoc's Avatar
My Feedback: (-1)
I had a Fun Fly that kinda pulled the same thing on me but I wasnt so lucky. It was a G-202 Funfly. I beleve it was super tiger that made it. I had it up 3 times before it died. I had an O.S. .46 SF on it, brand new. I was doing a high speed pas at full throttle. I was going to bring it front and center to pull straight up and do a few rolls, then hammerhead. As soon as I yanked back on the elevator, it snaped in 2 peices and dove straight for the ground. Didnt have enough time to pull the throttle down. I went out to recover what was left and the plane was demolished. I had an aluminum spinner on the O.S. which had cracked into 2 peices and the block was cracked. I was so dissapointed. I had Just got that motor and I had to replace the block already. Good thing I was working at a hobby store at the Time...
