Cub engine advice
My Feedback: (43)
hanger 9 80" cub. It came with the plug and play evolution 40 but i knew i was going to swap it so i didnt even put fuel to it. Money is real tight so should i put a broken in TT Pro 46 in there untill i can afford another saito 72. Or should i take the saito out of my edge put it in my cub right now and start saving to replace the edge with a OS 55 AX. What is the better engine for down on the deck 3D? Because i know the cub will get a four stoke sooner or later.
if 3d is what you want, saito 91's are great for 40 sized 3d planes, and put the 72 in the cub......but since money is tight and you dont have to spend anymore, just use the tt46 in the cub and youll be ok
