Which engine for PHOENIX EXTRA 330S
Dear All,
I recently bought an Extra 330 S from PHOENIX MODEL.
According to the manufacturer, a 2-stoke engine from 0.60 to 0.91 size is needed.
If some of you has this plane, could you tell me which engine you use? I would like to use, if possible, a 4-stroke engine, so which size would be needed?
I thank you a lot in advance.
Nicolas
Nicolas
Hi Brainiax,
Thanks for your answer.
Isn't a 120FS too much?
I would like it well powered but not too much, as I'm not interested in torqueroll for instance, and so on...
So, wouldn't a 0.90 FS be sufficient?
Nicolas
Nicolas
Hi Nicolas
Although I couldnt find the web site for your plane to look at the specs, I'm also building a 330s and have put a O.S. .91 supass II in it.. While I havent flown it yet, others I've talked to with similar planes and engines all tell me that it has plenty of power to do most anything you'd want..
See the following forum for pics and build info.. Some/all may apply to your plane as well
http://www.rcuniverse.com/forum/m_74...tm.htm#7485821
Rich
Rich
there is a thread on this plane, just do a search, I have one also, just haven't built it yet, too many projects...
I now plan on a O.S. 91 FS for the plane
Hi Finchase4 and Chuck993,
Thanks a lot for your answers!
I also think a 91 FS will be sufficient and I will use it.
Finchasa4, what is tha wingspan and weight of your Extra?
Nicolas
Nicolas
here is the other thread on the plane:
http://www.rcuniverse.com/forum/m_47...tm.htm#4798510
I originally was going to put an O.S. 120AX in the plane, but I am now putting that in a Showtime 90...
Hi Nicolas
Here are the specs on my 330s..
Specifications:
Wing Span: 63 in / 1600mm
Wing Area: 713sq in /46 sq dm
Flying Weight: 6.6 lb / 3000g
Fuselage Length: 60 in / 1520mm
Engine Required: 4c 0.91 cu in
Radio Required: 4channels, 5servos
I think the OS .91 is a good choice for these planes. If you want more power out of your .91, install a Graupner prop.. They have a lot more pull than others I've found..
Rich
Specifications:
Rich
Dear All,
According to what you say, I will definitely use a 0.91 4-stroke for this plane!!
Thanks again!
Nicolas
Thanks again!
Nicolas
Hey Guys,
I have another question: which propeller size would you advise with an OS FS 91 Surpass II?
Thanks a lot.
Nicolas
Thanks a lot.
Nicolas
I have a couple of O.S. 91 Surpass four strokes and they work well with a APC 13x8, 14x6, 15x4W for me...
I am running my Hanger 9 Ultra Stick 60 with a 14x6 right now and sometimes the 15x4W, which is great for hovering, etc...the 14x6 seems to work really well with that plane and engine...I use to run the 13x8 all the time, 14x6 is much better...I use all APC props.
The O.S. 91 Four stroke is an outstanding engine, starts right up, durable work horse.
What about a supertigre G90 i live at 4700 feet above sea level and like flyin 3D I seen one witha G75 and it just wasnt enough to hover, any input would be great.
Thanks, Jeff
Thanks, Jeff
