How to mix out? >
How to mix out?
How to mix out?
Old 05-08-2003 | 12:09 AM
Default How to mix out?
I have a Sig CAP 231EX that I am trimming out and need a little advise. The plane pitches quite a bit toward the belly when rudder is applied, making knife edges a bit ugly. How should I mix out that tendency? Use a pmix for the elevator or for the ailerons (flaperons)?
Mike
Old 05-08-2003 | 12:25 AM
You need to mix in a little up elevator with rudder.
Old 05-08-2003 | 12:33 AM
My Feedback: (31)
if you have the 8103 radio i used a -8 or -10 on the two i have back in the day point L 1 3 H point 2 stays a O (Zero)
That a rudder to Elevator mix
