 ca hinges >
ca hinges
ca hinges
Old 06-16-2008 | 03:20 PM
Default ca hinges
I just bought a arf Twist, it says to use ca glue on the hinges,is this some type of super glue? I have hing glue that looks milky color, will that work?
Old 06-16-2008 | 03:33 PM
Default RE: ca hinges
this is what they want you to use http://www3.towerhobbies.com/cgi-bin...&I=LXK282&P=ML
Old 06-16-2008 | 03:50 PM
Thanks, this will be my first time doing hinges hope it goes ok.
Old 06-16-2008 | 04:41 PM
turdfergerson's Avatar
While the glue is drying dont forget to keep the hinges moving, failure to do so will result in it being stuck in whatever posititon it was when you glued it. good luck!
Old 06-16-2008 | 04:53 PM
Get some T pins or push pins to center the hinge. Put the pin through middle edge of hinge so you get the same amount in each side. Just a drop or two at most is all it takes of this CA glue also. It spreads out through the hinge and holds. You also want to make sure you get the ail, rudd whatever your hinging to fit tight against pin. Once you put that CA glue on it will stick quick about 1.5sec. so be sure your right. Hope this helps a little.
Old 06-16-2008 | 06:42 PM
Always make sure you get the top & bottom of the hinge !!
