Help please Four Stroke in a Kadet Sr.
TX
I need a little advice on putting a four stroke in my Kadet Sr Arf.
The place is set up for a 2 stroke the 4 stroke i have has the throttle linkage on the other side. Whats the best way to get it to work.
thanks....
thanks....
Many four stroke's allow the carb to be turned 180 degrees. This MAY get you lined up with the stock cable. Other than that, it's cut and try.
Good luck
Good luck
